Search Forums | Classifieds (57) | Skins | Language
what adjuvant to use with harness and impact
nrlaa
Posted 1/12/2019 23:36 (#7241337)
Subject: what adjuvant to use with harness and impact
central MN
I am planning on using harness xtra and impact tank mixed together sprayed post on my corn this year. Impact label says to use mso when used by itself. Is the oil in the harness xtra enough? Or should I use coc or NIS instead? Should ams be used as well? I have seen harness products cause a little burn and dont want to cause more damage by using the wrong adjuvant. Thanks!
