Posted 1/12/2019 07:26 (#7239172 - in reply to #7238588) Subject: RE: Apache cummins 6.7 problem
Oakdale, Il.
That is normal. Run the engine for a hour or so and it will get all the air out. Next time when installing the filters, leave the secondary filter loose until you see fuel running out as you pump the hand primer.
