| look on one of the cylinders. if it's there, you'll the wiring harness....it's possible someone added autosense (though I think that was beginning 2009, it might have been added if the original sensor went bad). it's a about 2x3 inch black module near the articulation point....there should be a gray cable connected to it.....if the unit has the sensor in the cylinder, it's likely failed, or will do so soon. | |
