SE IL | As the other poster said have someone stand on the mixer and see if it's off. I wouldn't suspect the display is bad although it could be. It's possible that the calibration number got messed up too. If you zero the display does it stay steady plus or minus a couple of increments (1's, 5's or 10's)? If it bounces a lot or keeps counting up or down I would suspect a weigh bar. You can unhook them and then hook them back up one at a time to see which one causes the problem. If you can't figure it out you can call scale-tec or central city scale and they will gladly help you troubleshoot the system. | |
