Delta | gtroberson - 1/4/2019 14:21
We are looking at the attribute table for a cotton yield monitor on CP690 picker. It is a Deere monitor. It looks like it is creating 3 points simultaneously for each yield interval. On the map we see three points across the swath, all with the same attribute data, just three separate locations. Looks like a point for each pair of rows for the 6 row header. The yield values are not unique, the are all the exact same for each set of three points. Any one familiar with this setup or know why they are doing this?
It sounds like the data is logged in sections Since each set of rows like has its own set of sensors. This is an advantage of pickers over something like a combine where all the material passes over one single sensor. This would also be beneficial when section control reduces harvested width. |
