Ladoga, IN, United States, North America, Earth | The kinze vision does not come with an antenna if i remember correctly. I know that when you buy an insight it does not come with any antenna. The vision out of the factory is a glorified planting monitor till you add the reciever.
You will need a Agleader 1500 reciever atleast. That'll be about 1295. And I think that WAAS is as far as it will go.
For autopilot you will need atleast a Agleader GPS 5100 (AKA Trimble 252 Reciever). Somewhere around 4995. Then 2000 to omnistar, and another 2000 from omnistar to RTK. You will then need a RTK radio that is approx 3495 to get the RTK radio signal. So about 12,500 for a full blown RTK signal (no navII) The 262 is what you will get now if you go that route, or you could get the Trimble AgGPS 432/442 reciever/radio and get your RTK signal and GPS that way. Approx. 11,000 (no navII)
The 1500 will not run autopilot.
Edited by mcline 1/30/2009 22:39
