Posted 12/10/2018 18:05 (#7162407 - in reply to #7162227) Subject: RE: Toyota forklift help
ec. nebr.
Sounds to me like the motor is weak, causing a low vacuum when cranking! This vacuum is required to let the regulator open and function. On our old Ford truck, there was an electric push button to activate the regulator just like you do when manually pushing it to start. Maybe look into adding this to your regulator?
