North Central In. | We are needing a 1965-1970 Ford 4000 3 CYL. Steering Cylinder, it is the type that there is only 1 cylinder on left side of tractor,I think these may of been used on a few other Models of Ford Tractors Including Industrial models,It is the only model that only uses 1 cylinder on Left side ,other models have 2 cylinders 1 on each side this will not work. If you have something even if it leaks please let us know. Thanks | |
