Brookston, IN | If you have a Climate/ Fieldview account it is easy to do. That is how I moved our 2018 as planted data to SMS.
Log into fieldviewplus.com
Select the "Data" tab at the top.
Check the fields you want in the check boxes along the left edge.
Click the "Actions" drop down in the upper the right of the of the "Field Map Data" box.
Select "Export DAT Files"
It should give you an option of where to save them, once they are done you import them to SMS just like any other file. I would recommend not doing them all at once, the files can be big and take a while to process. I imported corn and beans as separate batches. | |
