N MO | Rolling ground here. Plant 6 with SF1 and shell 8. As long as you are working back and forth it works great. On curves I would drop marker and double check as it likes to go narrow but think that is because of no implement steering and it doesn’t comprehend windage to keep those rows correct on tight curves. Usually if you are planting 4-4.5 it’s really pretty close on adaptive cures when you are away from the end rows.
Straight track still works better and use that when at all possible.
Other planter is 16 row and does all bottom. No issues there at all even with lots of trees. | |
