| Batteries, glow plugs, injectors, glow plug relay, valve cover gaskets WITH pigtails the connections are done with Deutsch connectors. The voltage drop is less than 3/4 of a volt at the glow plugs, and compression test. Two low cylinders are 355 and others are 375-380.
At 60 ish degrees in the shop, the oil temp sensor says 54 degrees, the glow plug relay is set to be on for 74 seconds. | |
