Posted 11/29/2018 10:05 (#7135640 - in reply to #7131321) Subject: RE: PF3000 yield monitor problems
Hennepin, IL
Yup I'd check the PF and the switch. Next I'd check the fuse holder on the power harness, see if the fuse still fits tight. Check voltage at the console while messing with the harness to see if you can get it to lose power momentarily. If you can't make it lose power at the console, and everything looks good inside, its probably the switch.
