| Other poster is correct, need to determine which can voltage it has, the rear terminator is located under the rear grain tank cross auger on the right side above the fuel tank. The 4/5 terminator is black and the 2.5 is white, you need white. You also need to look at the label on the moisture sensor and make sure it says dual can which I believe all 10 series did. The second terminator is above the cab apolstry in the right front corner. If it's already 2.5 then you need your JD dealer to put software on a keycard so the moisture sensor can be updated to harvest doc for the newer displays to use. You can install the software yourself if you have a brown box and mobile processor with keycard once the software is put on it. Post questions if need help. | |
