| Go to your settings dial and turn it to the fan speed picture if your bottom number is lower than your top number turn the small knob on left of the escape button to the right or left to match the same fan speed number . You have to turn the header on and run at full throttle to do this. If it is still way low check your seperator fan variable speed belt for wear or you could have a bearing going out on the variable speed fan pulley, wiggle it
Edited by tex 11/13/2018 10:10
