East Central Ia | Figured out how, or Ag Leader finally added an easy way to true up data with actual weights.
I added all my fields actual wet weights from my grain cart this year.
But the only way to get them to show up in a report is to select “spatial data” for the record source. Instead if manual, or monitor etc.
My question is my acres are a bit short... one field has a bunch of waterways that we planted straight through and says we planted 97acs
Spatial says we harvested 89 acs.
Monitor or the other sources say we harvested 93acs or something.
Whats the most accurate?
We use RTK GPS in everything, GPS for the speed source, and have autoswath/shutouts on everything. With the accuracy in the monitor set to RTK for the autoswath.
Why the big discrepancy in acres? | |
