Central KS | I have done a couple setups on Gleaners like this where we had yield mapping and autosteer done through ag leader. It takes an adapter cable to get on the ag leader VT. The only downfall is that if your combine needs an update done thru the terminal, I don’t believe that you can do it through anything but a c2100. Usually your dealer will probably have one in another combine to make it work though as you probably won’t have to do that often
(721B0A02-5203-4DB1-AAD3-8FD44973A57A (full).jpeg)
Attachments ---------------- 721B0A02-5203-4DB1-AAD3-8FD44973A57A (full).jpeg (125KB - 38 downloads)
