NW KS | Sorry for the slow reply. I am not really familiar with the ag leader insight display but I looked through the user manual a little bit. I didn't see a whole lot on calibrating the navII from the display. Trimble has a program called autopilot toolbox that can be used to calibrate the navII also. You need a laptop with a serial port or USB serial port adapter to use it. You have to be careful with the program because there are advanced settings that can be changed with it too. Depending on your comfort level with computers it isn't really that hard to do either. Any Trimble or Case-IH dealer could likely calibrate the NavII box for you too. MIght check with someone more familiar with Ag leader about possibly calibrating from the screen but the earlier displays were primarily done with the autopilot toolbox program. | |
