Yale, Michigan | Using FieldIQ for VRT dry fertilizer for 2nd season. EZ Steer in port B, CAN in port A like they should be. Master switchbox communcates fine but Rate Controller does not - however, if I switch CAN communication to Port B, then I get Rate Controller but not master switchbox.
When I go to select the Controller in Implement setup, FieldIQ doesn’t give me the option to select Port A or B.
Any ideas? | |
