roaming | vhcloud - 10/21/2018 20:01
What is the proper way to set the flow delay on a Case IH 7088 with a Pro 700? Loading the maps in SMS, coming in and out of the headlands looks pretty good, but going through the field from pass to pass I'm not quite sure they line up correctly. I have it on 13 seconds right now, for what it's worth.
-Hunter
If you're seeing gaps at the END of each pass, your flow delay is too long. If you're seeing crop mapped in the headland (flow carrying into the headland instead of stopping at the end of the pass), then your flow delay is too short. Adjust a little at a time, and create a new Task after each adjustment.
Do the maps on the Pro 700 look good, and do they match your SMS maps? |
