Hennepin, IL | In the Cab app, go for home->settings->data->pick the year->pick the field->hit clear/build/rebuild map. I can't remember what that button says now exactly as it changed with a recent update, but it should say something about building a map. Let it clear and rebuild the map for that field and see if it showed up. If not, you may have to connect it to the drive and force it to sync, then repeat those steps. As far as the lag, that is normal. There is a lag of roughly 12 seconds from when grain goes into the head, that the machine sees the flow and is able to process everything it sees, therefore you have a lag of about that far. Now if you're leaving big red streaks either leaving or entering the headlands, but not both, you can adjust that lag. | |
