Central To Everything and Close to Nothing | Get the GS2 Rate Controller and a Raven Flow Control Kit (flow meter & control valve & harness). The price of the 440 box is about the same price as the Rate Controller flex box. This way you will have only one monitor in the cab, you will be able to do VR, and if you want to spend a little more, you could setup multiple sections and use Swath Control Pro to keep your overlaps down. |
