Posted 1/23/2009 08:48 (#581215 - in reply to #581062) Subject: Re: Spray controller
NEWTON, IL (SE IL.)
With the 450 you can keep all your components except the console & wiring harness.
Although it does depend on what harness you're using now, it might have the 6-boom sections in it.
If it has a rubber molded, 6-wire plug where you plug your sprayer & tractor together, you'll have to change the harness.
