| You should be able to make it work if you get the raven harness. If your ball valves are three wire it will work, all ball valves are wired the same. You should be most fo the way there. I would recommend having seperate rate controllers. You can use one but I just dont personally like moving them. Once you have them set up they stay setup, just plug in and go. You are going to need the implement side of the green star harness if you dont alreay have it also. | |
