Posted 9/28/2018 21:58 (#7014950 - in reply to #7014831) Subject: RE: Caseih rowguide
Tuscola, IL
The best solution I've found is to pull it off and put a trusight system on.
Other than that, the book calls for 8/10" between the two. You will want them centered. The system will try to equalize the signal voltage between the two sensors and it will align the row to the cornhead wherever that voltage is equal.
