Posted 9/28/2018 11:15 (#7013969) Subject: Crankshaft thrust washers (bearings) for CASE 1594
Phelps, NY
Rebuilding the bottom end in a CASE/David Brown 1594 and was able to find everything easily enough except the thrust bearings.
Case part numbers are:
K917636 lower
K917635 upper
I need standard size bearings. Anyone know if these bearings interchange with other engines? Measure the bearings that came out they appear to be about .093" thick 2.970"ID 3.620"OD
