Terril, IA | I think your problem might be that its trying to use the same .cn1 file that you have already preciously read into SMS. Try changing it slightly and reread in the data.
BEFORE DOING SO PLEASE MAKE A COPY OF THE FILE TO ENSURE NO LOSS OF INFORMATION!
Example: Your current file on the stick reads 161117o9.cn1 - Take the last digit on the file name ( in this case 9 ) and change it to a different single digit number.
Example: Changed file name from above 161117o8.cn1
Then reread the data into sms like you normally would and see if this populates your data. | |
