central ohio | I have been having problems the last few years with my brown box and mobile processor. This year it has stopped working completely. I had been toying with the idea of upgrading to a 2600 or a yieldsense. A friend of mine has a 2600 he doesn’t use in the fall so I was going to give it a try this fall.
I know that I have to get an adapter to go from the two rectangular plugs to the single square one on the back of the 2600. Doing a search it also appears that I have to update the firmware on the side mount moisture sensor. Is this available online and if so where would I find it. Once I get it into the card how do I download it to the moisture sensor?
I would like to do this myself if at all possible since I already have to spend $120 on the adapter and I may not even like the setup.
Thanks for any help you can offer.
Jeff | |
