Integra quirky issues
KenC
Posted 9/21/2018 12:44 (#7000863)
Subject: Integra quirky issues
Jefferson, SD
I keep getting the service screen on start up about 50% of the time. It has been doing this all summer, first in the hagie sprayer and again in the combine this fall. Each has it's own antenna so ruled that out.
Second issue is on occasion the direction arrow will be pointed backward and it thinks I'm moving the opposite direction. It doesn't record or work at all in this case.
The normal fix for either issue is to stop and reboot. Most of the time it comes back correct and works fine. Part of the time I need to reboot a couple times. I haven't tracked it closely but I think it's getting more frequent.
I've had the Integra since about 2012 and it has worked flawlessly until recently.
Where should I start to figure out this issue?
