Tuscola, IL | Have put 4 on this fall. Is this a trusight 2 system through the VT?
Basically, do the real quick calibration, engage it in the field, then nudge it over until it's aligned with the row. Probably will be the last time you have to touch it this season.
If it does start to wonder back and forth you can increase the 'gain' if it's lazy and decrease it if it's aggressive. They pretty much just work though. Unlike a typical guidance system that is trying to stay on an imaginary line and trying to keep an antenna that's 14' above that line in the right spot, this system is just looking at a voltage from a sensor and deciding if it needs to go left or right. Simplicity is the best feature of the system. | |
