Posted 9/19/2018 21:42 (#6997810 - in reply to #6997611) Subject: RE: Question for JD-9600 brain trust
Hazelton, Kansas
Devin,
Thanks. I wondered about oil leaking into the hydro pump. I think the hydro pump case drain just routes back to the reservoir, so case pressure should be low.
This machine had a reman hydrostat installed last year.
Hmmm.
MDS
Edit: And the oil is leaking from the gear case to the main reservoir.
