Bluffton, IN | That other plug with the white wire is just the protective cap for the combine side. Yes you will have to do a cal for the header control. with the clutches off and the box in the cab off: head up press and hold the "C" on the box until the led on the box flashes. Then lower header to ground and press and hold the "L" on the box until the light flashes. It should now be calibrated. | |
