Search Forums | Classifieds (52) | Skins | Language
JD 620i gator electrical
Hank, in Or
Posted 9/8/2018 13:09 (#6976901)
Subject: JD 620i gator electrical
Bonanza, Or
One of my JD 620i's has developed an electrical problem in the fused ECU circuit. It started yesterday with it just dying, would crank but not fire. No power to the fuel pump so this morn upon further investigation I found a blown 10 amp fuse in the ECU circuit so I replaced it and it fired right up. Used it some and all was well then restarted it ran 20 ft and blew the fuse again. I unplugged the fuel pump and it will blow fuses as soon as the key is turned on, has anyone else encountered this? Dead short or ECU problems?
