Butterfield, MN | The report will never get you more than what you see, they are just PDF's, and you set your high, on target, and low application settings on the Viper Pro just to have it show the different colors on the report. Keep in mind, this was based on programming from 15 years ago. The shape file will have the information you'll need, as long as SST Summit or whatever you are using is set up to read the columns correctly in the .dbf file. | |
