Posted 8/7/2018 05:16 (#6915754 - in reply to #6913307) Subject: RE: JD atu 200
I'm with you, I really like the Ag Leader OT3 setup. The ATU200's will work just fine on the articulated tractor. The only time you may see a little less performance is if the articulation joint is fairly sloppy. A lot of times after the installation is complete, plug in the factory calibration numbers from Deere, and you will be off and running.
