northwest ohio | looks like you have a 2.5 volt can system, which is good
You would need a mobile processor/harvest doc keycard on the back of your brown box
A JD ITC receiver would work fine(500-550.00 dollar range) this would get you yield mapping/recordable data
As far as desktop software, JD apex would allow you to read the data, or farmworks, im not sure if you can then go to climate, you could always go from APEX to the OPS center, then possibly Climate.....confusing I know
Good Luck! | |
