M | The case ih headed hieght is made by someone else that makes headed parts Hume or heart carter or someone like that. Don't shorten your bed like other post said .i tried on from bish and it didn't work the bearings get to close together and when it pulls hard it flexs and the chain will climb and jump . Mine was a bish setup I put a case ih hanger bearing and used my original shaft and shortened it then shortened the pto to factory length if you only want the pto shaft go to bish and shorten it. Mine was on a 1063 | |
