North Central Ohio | Stub cables often went bad. If not that, may try to located a different autosense to try. Many used ones can be found as systems get updated, etc...just ask an AgLeader dealer. Check antenna. I've had some get tipped over and rolling around on the cab roof.
I think touching on the yellow triangle (with exclamation mark) resets it. If not, a restart will reset it.
May need to send the Nav controller to AgExpress. Gyros may be acting up. I've sent many in over the years. They almost always would find something wrong with them.
Edited by sunman 7/12/2018 09:57
