Posted 6/26/2018 14:09 (#6835462) Subject: Rawson Par-E motor on Agleader or ISO controller
SW Ontario
I'm looking for info on how to run a Rawson Par-E motor in variable rate application. I can either use my AgLeader system or an ISO compatible controller. Is there an adapter cable or way I can make one? What signal does the Par-E use compared to the Par-2? I can add a separate shaft speed encoder if necessary, and I should be able to convert different voltages or signal types with an arduino if necessary. Thanks.
