North Central, South Dakota | toxhawk - 6/8/2018 08:59
Working on a 3320 Sprayer with the raven smartrax steering valve on it (i'll get the part number off the valve later and or post some pictures it has some din style connectors on it the way it looks) using the smartrax controler and Phoenix antenna. Wondering if it's possible to use that steering valve with another steering controller like an Ag Leader Steer Command. I've done a few trimble to agleader conversions but never tackled a raven setup i've heard they use a different type of valve block to do the steering but if it's not quite plug in play is it possible to change the way the valve block works and still be able to make use of it without having to redo the whole thing? I'm looking to get educated today, thanks in advance.
The part number for the valve is 334-0003-056
