Elizabethtown, ky | Installed a geosteer on an 8270r deere. Have been having trouble since day 1. First issue is it won't recognize the wheel angle sensor. When engaged it will turn right as hard as it can. When you unplug and replug the sensor it will work.
Also we have had to recalibrate several times because the roll calibration gets off and will drive off the line. It is also very slow to acquire the line. One direction it will drive on the line perfect, the other way it will be 6 inches off on one end and 2 inches off on the other.
I am running wass and know it is not sub inch accuracy, but it should still drive and hold the line.
Is steer command worth the upgrade? | |
