Butterfield, MN | There's a pretty good work-around for your first question. Make sure you have the software updated to the latest version (3.10.4.25). Look at Menu-About. Then look at Menu-Setup-Local-Units. Find the Shift data display option and check it. Now when this message box pops up, it will be at the top of the screen out of the way of everything, and you'll never really notice, since it's not in the way of your coverage. Unfortunately, Viper Pro never had the boom indicator on the guidance screen. You can only tell where the sections are when they're turned on applying. | |
