roaming | JDpicker1 - 5/24/2018 20:02
I have a 7230 case combine with steering valves and controller. What is required to run auto steer on this machine. Has a 700 display and 162 antenna
You can unlock the 162 for $1k, for WAAS-only autoguidance, or you can get a 262 or 372 and have better accuracy options. Otherwise you have everything you need. The 700 might need some extra software that your dealer can load, and he can verify that all controllers are up to date and compatible. |
