Posted 5/24/2018 08:39 (#6776386 - in reply to #6775936) Subject: RE: flexi coil 2320 cart
Davenport Washington
There can be more to it then that. First, have you disassembled the roller assembly? Dust and rust can get in between the meter rollers and the bearings making the whole assembly just a bit wider causing it to be very tight. You need to look at the meter housing it can corrode and cause tightness also.
