Posted 5/23/2018 23:18 (#6776020 - in reply to #6775369) Subject: RE: Re building deck plates
McCanna, ND
If they aren’t to far gone you should be able to weld them up and grind them back to size. We did our 600 series Deere last summer and the plates are thin enough I didn’t want to use the wire feed, ended up using hardfacing wire and tig welding them. Looked better then factory and should get about 3-4 seasons before it needs to be done again by the looks of it
