SW ND | I have a C3000 controlling a 9824 planter and the left side swath control works erratic. What happens is if you are planting a pie shaped piece and the left side is in the unplanted area and the right side sections are shutting off. When you get down to around row 6-8 left to plant they will all shut off at once. Leaving a little slice left. I then turn around and put the planter down and the right side will plant the unpainted area. Also when row one shuts off by itself it says there is a row failure on row 9. Dealer and agco rep have never heard of the shut off issue. | |
