| We had a 8260R in our area that would do odd things when the lights were turned on and was fine during the day. Found a loose connection on the rear of the cab where battery cable hooks to a main source and supplys the CLC controller. You would have to remove the rear cab cover that has the SMV sticker on it and then it's easy to spot. Also tighten all the screws in your planter and tractor 7 pin connector. | |
