Mondovi WI | Hi guys I have a pickup sprayer I put my 2600 in with a jd switch box and a single product rate controller. The sprayer was ran with a raven 450 I got a harness from agexpress to connect the jd harness and everything works as it should as far as sections and rate control. The problem is have is with the pump. The pump is a diaphragm pump and was turned on and off with the master switch by the raven. I have a switch on my council to turn pump on and off but need to run it on and off with the master switch on the jd switch box. Reason is this pump will produce positive displacement and won’t be good. My question is is there something I’m missing on setup or can rewire to do as I desire? Or dose this system not allow me too?
TIA
BleedsGreenWI
