| They took away the center option in an update, only let you shift it. And it goes back to your original line and shifts that line, then regenerates them across the field. It is supposed to be a more accurate way to shift a curve, since moving a curve over 2 inches doesn't accurately figure out the curve radius. So the further you are from your original line, the longer it takes to regenerate it to you and let you resume AT. It's annoying but supposed to be more accurate. You just hit shift, grab the wheel and steer over where you need to be and wait for the lines to get back underneath you, then resume. Or only shift at the headlands (start or end of pass). | |
