Search Forums | Classifieds (3) | Skins | Language
fm750 field iq spraying?
MX285driver
Posted 5/10/2018 18:32 (#6753784)
Subject: fm750 field iq spraying?
southern iowa
Set up my fm 750 with field iq for spraying with new sprayer specialties pull type. Just getting used to it today, all seems well except sometimes when spraying out of already sprayed area ( mostly endrows ) there is a gap before the mapping shows up, I believe ( but not sure ) that the spray is already spraying before the map comes on. I set the look ahead latency to 2 seconds. Other times it may just be an odd shaped triangle type shape not mapping . If I go over the gap again it usually sprays it again and maps it. Sometimes the spray comes on but does not map, and if I go over it another time it will spray it again and may or may not map it. Clear as mud I am sure. Wondering if I screwed up some setting, or if that is all fairly normal for the field iq spraying. Have used both an agleader versa and a topcon in the past and neither of them had this issue.
I had the look ahead latency set to 3 seconds for a while but could not really tell any difference in the mapping but it seemed like the spray came on way earlier. Thanks for any help.
