NW IA | I run a Kinze 3700 Iso planter through Ag Leader, a retro fit, with my MX315. All of a sudden I am getting a Working Set Failure message saying that Communication with the control unit timed out. Check cables, power and control unit. Everything seems tight so I'm lost. The Iso box is wired directly to the batteries, the monitor is connected to the post under the back side of the cab, all other connections lay on the floor of the cab and don't move. The antenna is connected through the Nav behind the seat. | |
